Misses and backfire
Engine will start missing and backfire when just starting to open throttle.
Will idle and rev up fine once past first opening throttle.
Has new propane regulator, fuel filter, spark plugs , wires , rotor and distributor cap. Changed pvc and vacuum hoses.
Vacuum advance is holding vacuum.
Compression test and cylinder leakdown test good.
Cleaned throttle body.
Has original distributor with high hours run time, never been changed.
Anyone know what may be cause?
Could coil or distributor cause this?
  • Posted 7 Dec 2021 06:59
  • By tdarr
  • joined 3 Dec'11 - 44 messages
tdarr@appi.us
It did this before the new parts were installed? Have you measured the KV's of spark? Use a spark tester...one that adjusts open to 3/4 inch.
In the air, a coil can fire 3/4 easily. Just using a spark plug is no good. Also, the pick up coil or igniter can go bad. You can buy complete distributor with coil and igniter/module for reasonable price.
  • Posted 7 Dec 2021 12:09
  • By Bluenose
  • joined 2 Apr'14 - 31 messages
  • Nova Scotia, Canada
Take me as i come, cause i can't stay long....
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
Aichi SR10C1SM
Terberg RT223
Aichi SR10C1SM
Terberg RT223
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
