miss firing
changed spark plugs cleaned lpg intake relaced gas converter found leaking
starts ok idles ok under load every now and then back fires
checked coil packs seem ok
any advice TIA
keith
[email address removed]
  • Posted 3 Dec 2024 19:01
  • By keith_roberts
  • joined 28 May'23 - 10 messages
  • New South Wales, Australia
Typically when it idles ok and backfires under load, it's a sign that one cylinders has poor spark. What resistance reading were you getting from the coil packs? It should be between around 0.15ohm and 2.15ohm. Otherwise it is possible you have a weak or bad spark plug.
I would recommend testing the coil packs and spark plugs, then make sure when reinstalling they are seated properly. Otherwise the issue may be further down the coil wiring.
  • Posted 3 Dec 2024 23:08
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 228 messages
  • Wisconsin, United States
November 3-4 2026 - Houston, United States
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Tampa Florida, United States
