Miscellaneous troubleshooting
Any body out there want to chat about servicing, troubles you run into, comments etc.?
Lets here from you.
  • Posted 28 Apr 2017 05:39
  • By UncleSi
  • joined 12 Feb'13 - 135 messages
  • Manitoba, Canada
Cheers I will check tomorrow
  • Posted 11 Jul 2017 08:37
  • By Bttowmotor
  • joined 18 Nov'04 - 14 messages
  • merseyside, United Kingdom
I just looked, the 100 Amp fuse is under the floor right (remove the whole plate with all the pedals on it) next to the main contactor. Under a little square plastic box.
  • Posted 11 Jul 2017 06:25
  • By UncleSi
  • Manitoba, Canada
Changed whole heater assembly. There is a 100 amp fuse in that heater circuit on one of the 2 heavy gauge cables. I wonder if it blew, as you are not getting voltage at Q31 contactor? It's not in the heater but buried under the floor or dash.I just forget?
  • Posted 11 Jul 2017 06:05
  • By UncleSi
  • Manitoba, Canada
New machine with new type heater with different fuses,contractor q31 not closing when heater pot turned. Checked pots ,contacts no voltage to 31. Can't find any wiring diagram did you change full heater or just fan.
  • Posted 8 Jul 2017 17:39
  • By Bttowmotor
Three machines new Feb.2014. Replaced all 3 original heater assemblies by 4000 hour mark. The replacement assemblies we received are quite different internally, I'll call them 2nd generation, have performed much better, just had one fail at 14,000 hours.
Have had a lot of fuses "melt". By this I mean the fuse isn't blown, the little fuse spades/terminals get so hot where they make the connection in the fuse block that they actually melt the fuse plastic and sometimes the fuse block itself. Poor connection =high amps= heat=meltdown ?? My guess.
I do not really care for the "variable speed" feature of these blowers/fans versus the old school 3 speed on the older style BT's, I have zero info on how to begin testing these newer assemblies, so just replace the whole thing. I'm assuming that is cheaper than the parts and labor to try and rebuild one. I could be wrong?
Hope this helps?
Are you having issues?
  • Posted 7 Jul 2017 23:41
  • By UncleSi
  • Manitoba, Canada
Si
Do you have any trouble with the heaters on the rre's
  • Posted 7 Jul 2017 06:44
  • By Bttowmotor
