MAZDA D5 MOTOR
Had motor rebuilt was getting water in the oil when they checked the motor found there where 2 plugs in the head it was coming from got it back now it is worse the it was before. WILL A F2 MOTOR FIT IN WHERE A D5 IS OR IS THERE A LOT OF DIFFERENCES LIKE EXHAUST, TRANSMISSION?
  • Posted 5 Jun 2024 20:25
  • Modified 24 Jun 2024 22:32 by poster
  • By DAVID
  • joined 5 Jun'24 - 5 messages
DAVID PELTON
OK THANKS
  • Posted 11 Jun 2024 21:52
  • By DAVID
DAVID PELTON
David,
The D5 and FE or2.0 are very similar. I believe they will swap though you may have a few issues with wiring. I will try and find additional information that may help. Thanks.
  • Posted 11 Jun 2024 21:34
  • By Fishmech
  • Virginia, United States
what size motor is the mazda D5 PROPANE like a 2.0 or a 2.2 ?
  • Posted 11 Jun 2024 08:39
  • By DAVID
DAVID PELTON
OK WILL TELL THEM THANKS
  • Posted 11 Jun 2024 05:17
  • By DAVID
DAVID PELTON
David,
They should have replaced all the plugs in the head, not just the ones that are leaking. They should have also quoted installing new valves and replacing the head gasket, timing chain and gears along with water pump. This is an old engine, but they hold up pretty good. The FE and F2 were better. Good Luck.
  • Posted 11 Jun 2024 04:46
  • By Fishmech
JLG launches YouTube University channel McConnellsburg, PA, United States
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
