mast lowering problem
5000lbs lift truck 3 stage mast. Free lift/carriage is lowering at twice the speed of mast channels/secondary cylinders.
Mast raises normal and has no problem lifting a load. When lowering from any height above free lift. The free lift will lower 1st and faster then the channels. If you release the handle to the neutral position the channels will continue lower and push Freelift up until the pressure is equalized. I have lubed the channels, have taken apart Freelift cylinder and resealed. Secondary lift cylinders have clear vent hoses at the top and there is no oil in the vents. At a loose as to what is causing this problem. I asked the customer if this problem just started with no warning or if the problem came on slowly....replied that problem just started out of the blue. I also chained up the carriage and lowered mast to see if the speed of the channels increased...only slightly faster.
Removed and disassembled a flow control valve that is in-line with supply line. Saw no obvious problems with valve.
  • Posted 25 Sep 2013 08:33
  • By hellcat
  • joined 19 Jan'13 - 4 messages
Sounds to me like there is a small "cushioning" valve in the bottom of the free-lift cylinder ram that has either gone bad or is leaking past or fallen out. You will need to pull the ram all the way out to see and change it. it is about as big around as your pinkey and about 1/2 as long and right in the bottom center of the lift cylinder ram.
  • Posted 25 Sep 2013 20:07
On the 88th day of the year, 29 March in a non-leap year and March 28th in a leap year, World Piano Day (also known as Piano Day) is celebrated. This date was chosen because a standard piano features 88 keys.
edition #1240 - 24 July 2025
CeMAT Australia 2025 has been underway in Sydney this week, wrapping up today, with the main topics coming out of the event proving to be the very predictable automation and sustainability... Continue reading
Terberg RT403
JLG 1932R
JLG 1932R 2017
Flesherton, Ontario, Canada
Simon Manasseh Simon Manasseh
VP business development for Europe, Noblelift Intelligent Equipment Co
Regional business manager, Doosan Bobcat Material Handling
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
