mast interlock indicator flashes & mast stops moving
The driving interlock indicatorn light starts flickering and the lift truck stops moving. Checked and veryfied seat sensor and safety belt found working fine.
  • Posted 27 Mar 2014 15:41
  • By pramod_m
  • joined 27 Mar'14 - 2 messages
  • Bahrain, Bahrain
Yes Uptime is a dealer only program.
  • Posted 16 Nov 2016 22:58
  • By Partsguy5
Is that a dealer program? I can plug in my obd2 scanner not sure if I would see seat switch signal?
  • Posted 16 Nov 2016 21:22
  • By Excel
  • joined 16 Nov'16 - 2 messages
  • Quebec, -
plug in and on uptime you can see whats happening have changed many a loom on these
  • Posted 16 Nov 2016 18:51
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
I have a similar problem ops light flashes with key on no travel no lift? I bypassed hood harness at connector by the air filter with no fix? Anybody have an idea?
  • Posted 16 Nov 2016 13:31
  • By Excel
  • Quebec, -
with seat switches being as they are, they can be inconsistant
just doing a general continuity check may not be good enough.
as a temporary test try bypassing the circuit at the harness connector under the hood and see if that makes any difference to rule out the seat switch being intermittent.
the seat belt circuit will have no effect on travel or lift on the OPS system, it generally just sets off a seat belt alarm or lights up an indicator on the dash if not buckled up.
  • Posted 21 Apr 2014 21:15
  • Modified 21 Apr 2014 21:16 by poster
Terberg YT220
Crown RD572513TT6860R
VETTER Industrie GmbH
Terberg YT220
