Mandos hidráulicos se bloquean pero no registra ningún código de error
Littoral Translation
Hydraulic controls lock but no error code is recorded
Good afternoon everyone
I have a problem with a hyster h280hd
The hydraulic controls lock but no code is recorded,
I turn off the device and turn it on again and it works for another few minutes until it freezes again.
Please use English Language
Buenas tardes a todos
Tengo un problema con una hyster h280hd
Los mandos hidráulicos se bloquean pero no registra ningún código,
Apago el equipo y lo vuelvo a encender y funciona otros minutos hasta que se vuelve a bloquear
  • Posted 25 Nov 2023 07:18
  • Modified 25 Nov 2023 08:52 by administrator
  • By Luis_Ospino
  • joined 25 Nov'23 - 1 message
  • Colombia
LYO FORKLIFT
Good afternoon, I have the same problem but with an H300HD forklift.
how did you solve the problem
Can you help me find the fault?
  • Posted 31 Oct 2024 09:34
  • By Jair_Emmanuel
  • joined 31 Oct'24 - 1 message
  • Mexico
Jair Martinez
Luis,
There could be a number of reasons the hydraulics cut out. What style of attachments are on the mast? Some will have proximity sensors that will fail, and hydraulics are locked out. I doubt this since you can turn off and back on and have hydraulics for a short time. I would suspect a failed connection in the estop switch, a malfunctioning priority valve or seat switch wiring issues. You can try calibrating the hydraulic handles. If you have single levers, disconnect the harness where they all connect with switch on, reconnect the harness and move each lever in forward position and hold for 3 seconds. Then move in opposite for 3 seconds. Complete this for each handle then shut lift off. Should you have a joystick, do the same thing, only you will have to complete each function, holding in each position for 3 seconds. Since you have no codes i do not know what else to suggest. One other thing, if it is in a cold environment, the hydraulics need to warm up before operating any functions. Thanks.
  • Posted 28 Nov 2023 01:28
  • By Fishmech
  • Virginia, United States
May 14, 2026 - Blair Athol, South Australia, Australia
edition #1276 - 9 April 2026
In this week’s Forkliftaction News , we continue our coverage of LogiMAT 2026 held in Stuttgart with a rundown of some of the biggest product launches at the event which achieved record exhibitor and visitor numbers... Continue reading
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
UN Forklift FBRP15NQZ2
Hangcha CBD15
China
USD1,600
