Maintenance Required Light
2015 model, 2,600 total hrs, 1,900 traction hours.
Turn the key on, it automatically says "charge battery" and then says "maintenance required". All three LED's are lit.
Charge battery up, shows 24.6 volts, no change. Hooked it up to another known good battery, same thing.
Truck is in limp mode, will drive slowly but no lift.
Any suggestions on where to start? Thanks!
  • Posted 2 May 2024 04:41
  • By Inane222
  • joined 26 Jan'24 - 4 messages
  • Kentucky, United States
Inane,
Using the program through the computer, the BDI has 5 different settings. Each setting is normally changed over time when the lift is first purchased. 25.6 volts is a little low to reset the BDI. What battery do you have in it and what is the fluid level of each battery. If you have 4 lead acid batteries, you may need to remove cables and test each individually. One low battery could drag the voltage down. If the batteries all check good and you can pull up all battery settings, lower the BDI start up full by 1 to 3 and set the BDI reset to 45%. Good Luck.
  • Posted 21 May 2024 22:01
  • By Fishmech
  • Virginia, United States
Thank you fishmech.
I bought a Curtis full level 1313 handset last week. I was able to reset the maintenance minder and max out the hours where it shouldn't come back on. The red wrench light went out and no more messages.
The BDI still has me in limp mode. Battery is at about 25.6. I've been charging it with the onboard charger. Then, I tried charging it with a different charger by pulling it next to another truck. Finally, I plugged a different battery into this truck but getting the same BDI warning. I may have overlooked while digging around in the handset, but is this something I can reset with the programmer?
Thanks again!
  • Posted 21 May 2024 07:25
  • By Inane222
Inane,
You will need a service tech to connect either a handset or computer to reset the maintenance reminder. Then you need to have them to turn it off. This will set so it does not return. There is no other way to reset. Good Luck.
  • Posted 21 May 2024 00:28
  • By Fishmech
Taylor TT300
USD98,500
Taylor TXB180S
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
