main lift cylinder will not lift
I hope I can get advice from some experts. I have a Crown Lift that when you operate the controls for the main cylinder lift nothing happens. I found two switches one is set to normally open and the second to normally closed. I guess they are for the speed of the lift. All fuses I can find look good. Any trouble shootings steps I can take to troubleshoot?
  • Posted 18 Feb 2023 01:10
  • By RickPeaches
  • joined 18 Feb'23 - 2 messages
It is a possibility for the low battery. I just received it and the charger is not hooked up yet. I will give that a try thank you.
  • Posted 19 Feb 2023 08:16
  • By RickPeaches
you sure the truck is not in lift interrupe if the battery is weak or very low it will not allow you to lift l would look at that first try to charge the battery and than see if it lifts you might be chasing a problem that is not there. If that does not fix it try look at the hyd contactor see if you can manually push it in to see if the hyd motor turns on it is possible you have a bad motor
You also could put a meter on the two cables at the motor and pull the hyd handle to lift and see if you have battery voltage to the motor. Also check the switches that you talk about in your post that is what signals the contactor to close make sure that when you pull the hyd handle that the switch is closing l seen them come out of adjustment and not close. Hope l was of some help.
  • Posted 19 Feb 2023 07:20
  • By Scott_
Scott
Maxlion R2D25
Taylor T650L
Maxlion R2D25
Taylor T650L
