lp fuel
I have an old s150A with a continental f245 engine and impco model j and a c125 carb. I have replace diaphram and model j and if you don't choke it it won't run. It is running too lean I have moved power valve back from lean to rich and no difference. What do I do now?
  • Posted 18 Aug 2008 08:45
  • By wellfred
  • joined 17 Aug'08 - 3 messages
  • Kentucky, United States
keep smiling
The big screw on the side of the c125 is the idle mixture.
Clockwise=richen.
The power valve under the fuel inlet is for top-end adjustment.
Impco's don't work well with worn-out engines, not enough vaccumn...
Impco has a kit availible, to increase the fuel pressure of the vapourizer. It works well, I've used them when converting LPG to CNG. P/N on the bag is ACI.74 600623.
Hope that helps...
  • Posted 19 Aug 2008 02:29
  • By mike_n
  • Alberta, Canada
Hoist Liftruck F180-36BOX-CAR
SMV (Konecranes) 4531CC5
Briefs United States
