Lowering the lift cylinder hardly
Hello, I have faced with a problem that when lifting without load everything works well but in lowering it gets hard and needs more power, it means I have to increase the engine rpm to start lowering.
Where is the problem?
  • Posted 25 Jun 2024 07:13
  • By Sajad_Rajabi
  • joined 23 May'24 - 13 messages
  • Iran, Islamic Republic Of
Kind regards
S.Rajabi
There is a velocity fuse on that cyl as well
If you do replace it make sure you look at old one to get value off of it for the replacement
  • Posted 27 Jun 2024 07:55
  • By John_Bradley
  • joined 10 Aug'22 - 301 messages
Jb69
Thanks a lot , I will check them
  • Posted 27 Jun 2024 07:44
  • Modified 27 Jun 2024 07:45 by poster
  • By Sajad_Rajabi
Kind regards
S.Rajabi
At top of each cylinder where the line hooks up there is a velocity fuse in bottom of fitting
Possibly one of those also look at hyd fluid for small flakes of metal in past Linde used velocity fuses that would flake off and get into the control valve causing said issue next would be lowering valve issue.good luck !
  • Posted 27 Jun 2024 07:05
  • By John_Bradley
Jb69
You mean velocity fuse malfunction? Yes?
  • Posted 26 Jun 2024 07:43
  • By Sajad_Rajabi
Kind regards
S.Rajabi
I think you have a broken hose valve
  • Posted 26 Jun 2024 04:56
  • By michel_v
  • joined 8 Mar'08 - 1,039 messages
  • noord holland, Netherlands
Hi, thanks for your message, but it's just while lowering the lifting cylinder. Not for all
  • Posted 26 Jun 2024 04:16
  • By Sajad_Rajabi
Kind regards
S.Rajabi
Hi, could it be a low idle voltage problem?
  • Posted 25 Jun 2024 23:39
  • By Koldo_Martinez
  • joined 11 Mar'23 - 15 messages
  • Spain
Thanks all!
October 12-15, 2026 - Detroit, MI, United States
Stu Jacover Stu Jacover
Chief executive officer, TVH
