Loss of steering at high speeds.
SN 020254AE
Unit has a problem with the high speed steer. I loose the steering all together to the right and it takes several switch engagements to activate the left. Was able to switch wiring and same this in opposite directions. Any ideas would be be greatly appreciated. I have a hydraulic diagram if anyone has any further info for this brand and model would be wonderful.
  • Posted 5 Nov 2013 04:27
  • By Bulldog965
  • joined 15 Oct'09 - 63 messages
  • Indiana, United States
Richard
Sounds like you have a spool coil going bad or the spool has dirt in it......find which coil it is and ohm it and the other and see if there is a difference ?........does this do this at low speed or stopped......how about when your raised above the lift cutout switches if it has them???Does it have pothole guards that drop down when your raised?
  • Posted 5 Nov 2013 05:52
  • By kevin_t
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
edition #1302 - 8 October 2026
In this week’s Forkliftaction News , we have two stories reminding us of the power of a generous spirit... Continue reading
Syrian port receives 16 new forklifts Latakia, Syrian Arab Republic
