Load Wheel Replacement for Raymond 20RA30TT Electric Reach Truck
Hi,
I have been assigned with the task of replacing the two front left polyurethane load wheels on my Raymond 20RA30TT Reach Truck (SN - 020-85-24346). I currently have the front left outrigger raised and supported on blocks. It appears that the end of the outrigger is constructed of two pieces, and can be unbolted. Do these plates need to be removed to replace the wheels? It also appears that there are two off centered roll pins on the side of the axle, which pass through another rectangular plate that sits inside the other two large outrigger plates. Can I drive out these two roll pins to remove the wheels?
Thank you for your assistance.
  • Posted 18 Jun 2010 06:37
  • By ToddCFusion
  • joined 18 Jun'10 - 1 message
Noblelift
Sue Tomic Sue Tomic
