Linde speed limit problem
Hello everyone.
I have a problem with Linde H20D 391 series.
The speed limit is 9 km/h. Pathfinder isn't able to rise it.
There is no LFM or other safety devices.
ECU: 390 360 19 61.
Any advice?
Best regards.
  • Posted 19 Sep 2022 23:06
  • By Jaccobi
  • joined 27 Jul'22 - 9 messages
  • Poland
Sounds like it could be a upa controller
Set to 9 ks and unable to change
  • Posted 23 Sep 2022 07:49
  • By Lindetechnz
  • joined 28 Apr'21 - 58 messages
  • New Zealand
Lindetechnz
Everything there is also OK, set to 20 and the option is turned off
  • Posted 23 Sep 2022 07:47
  • By Jaccobi
  • Poland
Best regards
Go to the switch controlled speed tab and check what it is set to there
  • Posted 23 Sep 2022 07:45
  • By Lindetechnz
  • New Zealand
Lindetechnz
It is not possible to change anything if the speed is 9 km/h.
Less - ok I change
More - no change
  • Posted 23 Sep 2022 07:41
  • By Jaccobi
  • Poland
Best regards
That's why only 9 ks
Change pump to 100 and Tom to max
  • Posted 23 Sep 2022 07:39
  • By Lindetechnz
  • New Zealand
Lindetechnz
You can set the rpm and pump angle but the sumaric is not allowed to exceed 9 km/h
1510 rpm and 40% pump angle as I remember.
Copying traction files from other ECU's doesn't help.
  • Posted 23 Sep 2022 07:35
  • By Jaccobi
  • Poland
Best regards
What is the max engine rpm set too and the pump angle?
  • Posted 23 Sep 2022 07:33
  • By Lindetechnz
  • New Zealand
Lindetechnz
2012 year
  • Posted 23 Sep 2022 07:22
  • By Jaccobi
  • Poland
Best regards
What year is the machine
  • Posted 23 Sep 2022 07:20
  • By Lindetechnz
  • New Zealand
Lindetechnz
