Linde R16HD hydraulic only in slow mode
Truble is only in lifting it works in very slow mode when i try with joystick to move forks up.
No error codes comes. (Sometime i can have turtle and service book symbols), but mostly not. Hydraulic seems very tired...slow.
Battery is OK and i can move fast forward an back and everything seems normal.
I have tried to Check fuses and cables connectors
Serial No: G1X115N50016 2002
  • Posted 19 Feb 2021 03:39
  • By John_Bjorn
  • joined 19 Feb'21 - 7 messages
  • Sweden
TJ
Showing items 1 - 15 of 15 results.
Q tal buenos dias
Si podrías ayudarme. Tengo un equipo R16HD con un mensaje H.br en display al mover el volante se bloquea y sale el mensaje
Favor tu ayuda
Saludos
  • Posted 12 Jul 2021 04:50
  • By Carlos_Gomez
  • joined 20 Mar'20 - 16 messages
  • GUAYAS, Ecuador
Carlos Gomez
Thanks, its nit that switch in this model, i cant find any cables for such switch.
  • Posted 13 Apr 2021 03:55
  • By John_Bjorn
  • Sweden
TJ
Maybe in NZ but not in Europe they don't worked on plenty
  • Posted 13 Apr 2021 03:51
  • By lifter01
  • joined 4 Jul'09 - 463 messages
I used to build them
All 115 reach trucks have a lift slow down switch fitted to the mast
  • Posted 9 Apr 2021 19:28
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
Its not such a switch on this model, its to old.
  • Posted 7 Apr 2021 19:33
  • By John_Bjorn
  • Sweden
TJ
There is a switch on the left hand cylinder that activates if the mast is above 8.5 meters
European regulation!
It's a roller type switch that is activated by a cam on the mast channel in the left
  • Posted 7 Apr 2021 19:25
  • By Lindetech
Okej, i check this also, thanks.
  • Posted 20 Feb 2021 04:54
  • By John_Bjorn
  • Sweden
TJ
If you've changed a joystick it will need calibrating or it will stay in limp mode and Lift slowly
  • Posted 20 Feb 2021 04:33
  • By lifter01
you got mail.
  • Posted 19 Feb 2021 18:32
  • By Justus
  • joined 23 Aug'20 - 37 messages
  • Finland
Ok, i will check that. My epost is tord at post dot com
  • Posted 19 Feb 2021 18:15
  • By John_Bjorn
  • Sweden
TJ
If i remember right linde has several types of sensor but look right side lift cylinder upper side. i have picture but cant share it here.
  • Posted 19 Feb 2021 18:13
  • By Justus
  • Finland
I cant find any cabels for that on the lift tower? Is that sensor on top, midle or low area? Is sensor inside tower or visible?
  • Posted 19 Feb 2021 17:56
  • By John_Bjorn
  • Sweden
TJ
ok. is there mast sensor? if height sensor doesent work it could make this prob.
  • Posted 19 Feb 2021 17:49
  • By Justus
  • Finland
Hi thanks
I have changed joystick cabels and no change in action. Same problem still.
  • Posted 19 Feb 2021 17:45
  • By John_Bjorn
  • Sweden
TJ
hi!
chance lift and some another joystick connector each other. if the fault chance to another hydr action the fault is in joystick or need calibration.
  • Posted 19 Feb 2021 17:39
  • By Justus
  • Finland
Mitsubishi FGE35AT
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
