Linde R16HD hydraulic only in slow mode
Truble is only in lifting it works in very slow mode when i try with joystick to move forks up.
No error codes comes. (Sometime i can have turtle and service book symbols), but mostly not. Hydraulic seems very tired...slow.
Battery is OK and i can move fast forward an back and everything seems normal.
I have tried to Check fuses and cables connectors
Serial No: G1X115N50016 2002
  • Posted 19 Feb 2021 03:39
  • By John_Bjorn
  • joined 19 Feb'21 - 7 messages
  • Sweden
TJ
Showing items 1 - 15 of 15 results.
Q tal buenos dias
Si podrías ayudarme. Tengo un equipo R16HD con un mensaje H.br en display al mover el volante se bloquea y sale el mensaje
Favor tu ayuda
Saludos
  • Posted 12 Jul 2021 04:50
  • By Carlos_Gomez
  • joined 20 Mar'20 - 16 messages
  • GUAYAS, Ecuador
Carlos Gomez
Thanks, its nit that switch in this model, i cant find any cables for such switch.
  • Posted 13 Apr 2021 03:55
  • By John_Bjorn
  • Sweden
TJ
Maybe in NZ but not in Europe they don't worked on plenty
  • Posted 13 Apr 2021 03:51
  • By lifter01
  • joined 4 Jul'09 - 465 messages
I used to build them
All 115 reach trucks have a lift slow down switch fitted to the mast
  • Posted 9 Apr 2021 19:28
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
Its not such a switch on this model, its to old.
  • Posted 7 Apr 2021 19:33
  • By John_Bjorn
  • Sweden
TJ
There is a switch on the left hand cylinder that activates if the mast is above 8.5 meters
European regulation!
It's a roller type switch that is activated by a cam on the mast channel in the left
  • Posted 7 Apr 2021 19:25
  • By Lindetech
Okej, i check this also, thanks.
  • Posted 20 Feb 2021 04:54
  • By John_Bjorn
  • Sweden
TJ
If you've changed a joystick it will need calibrating or it will stay in limp mode and Lift slowly
  • Posted 20 Feb 2021 04:33
  • By lifter01
you got mail.
  • Posted 19 Feb 2021 18:32
  • By Justus
  • joined 23 Aug'20 - 37 messages
  • Finland
Ok, i will check that. My epost is tord at post dot com
  • Posted 19 Feb 2021 18:15
  • By John_Bjorn
  • Sweden
TJ
If i remember right linde has several types of sensor but look right side lift cylinder upper side. i have picture but cant share it here.
  • Posted 19 Feb 2021 18:13
  • By Justus
  • Finland
I cant find any cabels for that on the lift tower? Is that sensor on top, midle or low area? Is sensor inside tower or visible?
  • Posted 19 Feb 2021 17:56
  • By John_Bjorn
  • Sweden
TJ
ok. is there mast sensor? if height sensor doesent work it could make this prob.
  • Posted 19 Feb 2021 17:49
  • By Justus
  • Finland
Hi thanks
I have changed joystick cabels and no change in action. Same problem still.
  • Posted 19 Feb 2021 17:45
  • By John_Bjorn
  • Sweden
TJ
hi!
chance lift and some another joystick connector each other. if the fault chance to another hydr action the fault is in joystick or need calibration.
  • Posted 19 Feb 2021 17:39
  • By Justus
  • Finland
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Philadephia, PA, United States
Chandler, United States
UN Forklift FB25N1LZ1
Aichi SR18A
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Aichi SR18A
