Linde L14 ERROR 46 (44)
I have carried out all the tests for this code - checked hydraulic contacts for shorting and run the pump motor with an external power supply. The UD on one side of the contactor (pin 9 on the LLC) is 20.1 volts and the UC is about the same (Truckdoctor). If I disconnect the wire from the contactor the UD drops slightly and the UC then equals 0 Volts. I then get error code 44, which was the original problem before I had the LLC tested with no problems found. Has anyone had experience of this who can offer any suggestions?
  • Posted 16 Oct 2019 20:09
  • Discussion started by Gaza
  • Australia
Check the voltage drop Um and Ub in window 61:
If the voltage> 0 V LDC power module damaged.
tvh cannot regenerate modules properly. for 5 items - 3 were damaged right away.
  • Posted 21 Oct 2019 00:17
  • Reply by Lukasz
  • Poland
Greetings
Lukasz
Hi Lukasz
It's a 2005 truck and I have Truckdoctor, which is giving me the Error code 46. In Truck Expert it says in window 6.1 (Truckdoctor) that a short circuit the Ud = 21.0, which I have but the2k11 contactor is not shorted so I'm at a loss unless TVH hasn't found a fault with the LLC when they tested it
  • Posted 18 Oct 2019 19:13
  • Reply by Gaza
  • Australia
->2010, trouble codes are in TruckDoctor.
2010 -> trouble codes are in PAthfinder.
  • Posted 17 Oct 2019 20:22
  • Reply by Lukasz
  • Poland
Greetings
Lukasz
Do You have a nameplate this truck?
whicz version truck?
  • Posted 17 Oct 2019 20:01
  • Reply by Lukasz
  • Poland
Greetings
Lukasz
Hi
Thanks for the reply and yes it is 372 series
  • Posted 17 Oct 2019 19:44
  • Reply by Gaza
  • Australia
Hi,
372 series?
  • Posted 17 Oct 2019 07:35
  • Reply by Lukasz
  • Poland
Greetings
Lukasz
