LINDE H30D errors
When the ignition key on, flashlight icon on monitor, starter does not twists and the screen displays the following error T231, T238, T381.
year of build 2004, serial number H2X393R02890. Maybe someone has a list of errors for this forklift?
Thank you very much. Best regards
  • Posted 28 Feb 2014 16:20
  • Discussion started by Malah
  • Ekaterinburg, Russia
Showing items 1 - 15 of 27 results.
is the 12v a fixed voltag
whits eror code is on????
  • Posted 10 Jul 2021 16:06
  • Modified 11 Jul 2021 05:13 by poster
  • Reply by michel_v
  • noord holland, Netherlands
Control circuit are only 12v & 13v
There is no 24 volts circuit
  • Posted 9 Jul 2021 17:44
  • Reply by namdev_s
  • maharashtra, India
and de converter 80v to 24 volt ???? it ste stedy
  • Posted 8 Jul 2021 06:21
  • Reply by michel_v
We have daut on LDC failure
We have checked all charging circuit there is no issue.
Once we start key switch when we check voltage at Power module it going decrease
  • Posted 5 Jul 2021 21:30
  • Reply by namdev_s
  • Posted 5 Jul 2021 21:25
  • Reply by namdev_s
look at battery leakage voltage?
or to the converter 80v to 24 volt
  • Posted 25 Jun 2021 03:59
  • Reply by michel_v
T 234 Accelerator drive and reference signals do not match
  • Posted 24 Jun 2021 05:58
  • Reply by michel_v
When battery 100% full than error code continues showing on display. When battery is 80/60% than turck will working properly.
Sir please suggest us
  • Posted 23 Jun 2021 20:59
  • Modified 23 Jun 2021 21:00 by poster
  • Reply by namdev_s
Hi
Sir we have in our factory linde E80 1279 model turck
The error code T-334 is currently showing display
We are chek everything of turck like 2A1 power module also change 2A2
Sir please suggest what we do
  • Posted 23 Jun 2021 20:55
  • Modified 23 Jun 2021 20:56 by poster
  • Reply by namdev_s
Hi. Can I have please a list of all error for Linde H30?
Thanks!
  • Posted 14 Jan 2019 22:00
  • Reply by Florin
  • United Kingdom
Florin
Fault D 156
Precondition:
The controller of the display unit has not received a heartbeat message from the traction controller for more than 400 ms.
Important!
Signal lamps
H1 (Oil temperature)
H4 (Fault in electrical control system)
H5 (Engine temperature)
light up.
Effect on the truck:
None
Possible causes:
1. Connector (6X1) defective.
2. Connector (X15) defective.
3. Display unit defective.
  • Posted 9 Feb 2018 06:24
  • Reply by michel_v
Hi,
I'm having a problem with a Linde H30D
. Fault D156 on display when key on. Truck starts 9 out of 10 times when it starts fault disappears. Also sometimes you can't select direction. Any ideas?
Thx
  • Posted 8 Feb 2018 22:34
  • Reply by jos_v
  • oost-vlaanderen, Belgium
[email address removed]
  • Posted 27 Nov 2016 21:26
  • Reply by mohanraj_k
  • karnataka, India
Version 1.0
Fault 221 Lifting
Precondition:
The controller detects that the joystick and reference signals of the tilt angle sensor are incompatible.
Lowering is possible, lifting is possible at reduced speed for 1 sec.
Possible causes:
1. Tile angle sensor (2B3) defective.
2. Connection between tilt angle sensor (2B3) and controller (N1:30,N1:88,N1:103,N1:118) faulty.
  • Posted 8 Nov 2016 17:46
  • Reply by michel_v
Fault T 235
Precondition:
An invalid combination of travel direction signals has been detected.
For dual-pedal trucks only the following combination is permitted:
N1:37 N1:36 N1:72 N1:56
1 1 1 0
In case of all other combinations a fault is signalled.
In the case of single-pedal trucks a fault is signalled if the following combinations are present:
0 0 0 X
1 X 1 X
X X X 0
0 = open, 1 = connected to ground, X = signal not evaluated
Stop
Possible causes:
1. Travel direction switch (1S2) defective.
2. Coding connector (1X3) defective.
3. Connection between controller (N1:36, N1:37, N1:56, N1:72) and coding connector (2-pedal truck) or travel direction switch (1-pedal truck) faulty.
4. Strong magnetic fields in connection with single-pedal trucks may cause unplausible signals at the reed contacts of the travel direction switch.
  • Reply by michel_v
edition #1235 - 19 June 2025
