Linde h30d-02
Lift starts and dies with new injection pump and new injectors. Every once in a while the lift will start up and run fine, but once you turn the lift off it will not start back up. Now the lift just cranks and over. I changed a ecu with a sister lift and it will just start up and die.
  • Posted 28 Sep 2022 07:25
  • By Luke_Field
  • joined 28 Sep'22 - 2 messages
Luke
Injector pump got changed because there was low pressure from what it was actually commanding. Once I changed it the value and command pressure became the same. But still fighting the no start
  • Posted 30 Sep 2022 03:50
  • By Luke_Field
Luke
Why did you change the injector pump? The only issue i have ever heard about any injector pumps is leaks.
  • Posted 29 Sep 2022 21:47
  • By duodeluxe
  • United States
duodeluxe
Mobicon 2T
Terberg YT220
Mobicon 2T
Terberg YT220
Noblelift
