Linde h25d error code l290,l291
Help i have a problem linde h25 error code l290,l291
  • Posted 30 Apr 2019 00:08
  • Modified 6 Dec 2019 06:30 by poster
  • Discussion started by nedko_s
  • Bulgaria
hello i have problem linde h25d with codes l90,l291 if you can dare to give information thanks
hello please help if anyone has schematics of installation and computer hydraulics as well as resilient installations after the heat and i have eror cod l290-l291 thank you in advance
  • Posted 6 Dec 2019 06:33
  • Reply by nedko_s
  • Bulgaria
hello forklift it is still divorced and you will be very grateful if you help me with any schematics of the installation and the computer which is such that you want to take care of the necessary installations but if you want to connect with an error l290 l291 check the coils and solenoids are healthy fork moving but hydraulics don't respond please help beforehand
  • Posted 6 Dec 2019 06:29
  • Reply by nedko_s
  • Bulgaria
Hi.problem i will turn out in the computer today i opened it and when i give the contact starts to heat a part i apply and the photos i will ask some if there is circuit on the PCB controlling the hydraulics thanks. https://m.pt.aliexpress.com/item/32760788245.html?trace=wwwdetail2mobilesitedetail&productId=32760788245&productSubject=TLE4267G-4267G-4267GV
  • Posted 5 May 2019 21:06
  • Modified 6 Dec 2019 06:34 by poster
  • Reply by nedko_s
  • Bulgaria
take a good look at the wire harness behind the seat where it enters the engine room
  • Posted 5 May 2019 15:43
  • Reply by michel_v
  • noord holland, Netherlands
Fault D 158
Precondition:
The controller of the display unit has not received a heartbeat message from the lifting controller for more than 400 ms.
Important!
Signal lamp H4 (fault in the electrical control system) lights up.
Effect on the truck:
None
Possible causes:
1. Connector (6X1) defective.
2. Connector (X15) defective.
3. Display unit defective.
  • Posted 5 May 2019 15:36
  • Reply by michel_v
Fault 380 Traction
Precondition:
The controller detects that the communication system within the controller has not received any signals from the safety processor for more than 5 seconds.
Stop
Possible causes:
1. Breakdown of the power supply, so that the power supply is enabled only by one reset block.
2. Controller defective.
  • Posted 5 May 2019 15:34
  • Reply by michel_v
158 Lift controller / Heartbeat message missed for more than 400 ms.
start by checking fuses
  • Posted 5 May 2019 15:32
  • Reply by michel_v
Hi , you have shorted harnas or defect lift control unit
  • Posted 5 May 2019 04:42
  • Reply by gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Linde erorr
  • Posted 5 May 2019 04:22
  • Modified 6 Dec 2019 06:42 by poster
  • Reply by nedko_s
  • Bulgaria
Fault description
The controller detects that the current through the circuit of the safety valve (2Y9) is greater than 5 A.
Result
Working hydraulics disabled.
Possible causes
Safety valve (2Y9) defective.
Connection between controller (N1:109,N1:111) and safety valve (2Y9) faulty.
Internal fault in the controller.
  • Posted 4 May 2019 16:29
  • Reply by michel_v
Fault description
The controller detects that the current through the circuit of the safety valve (2Y9) is too high.
Result
Possible causes
  • Posted 4 May 2019 16:22
  • Reply by michel_v
hello , on hydraulic block you find the safety solenoid valve , i think wiring broken or connector loose. Current to high
  • Posted 1 May 2019 19:43
  • Reply by gc_d
Regards gc_d
Harrisburg, SD, United States
Ottumwa, IA, United States
Wentzville, MO, United States
Kalmar DCG16-900
UN Forklift FGL35T
edition #1235 - 19 June 2025
