linde H18t-03 engine stops
can anyone help with this linde.? Runs great for 2 to 5 minutes then the power is lost to the lpg lockoff valve. Red lightning arrow on dash flashes rapidly, cranks over fine and has spark. Let sit for 5 minutes and will start as normal and run for 5 minutes.
  • Posted 11 Aug 2009 13:03
  • By mrforklift
  • joined 10 Aug'09 - 39 messages
  • Queensland, Australia
Ive had this a few times, if gas solenoid has poor connections or is just breaking down it takes out control module.
Open module and look for small contact set, turn board over and look for dry/cracked solder joints on largest contact points.
Not sure if solder melts under load, but you can usually re-solder joints and all works again.
I usually replace gas solenoid at same time - not over expensive
  • Posted 12 Aug 2009 04:43
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
GemOne
Taylor T520M
Toyota 3FD100
GemOne
