Lift wheels will not move
I have troubleshot this problem with a multimeter and have narrowed down to the handle I believe. The battery pack checks good at every terminal. I am getting a fault 1-1. Which is a generic battery fault. the forklift operates fine, we have replaced the contactor with no luck still. When we try to drive it the wheels wont move. I've lifted it in the air and nothing changes.
Im curious what part could be changed in the handle that could be causing this issue.
  • Posted 24 Jun 2025 04:49
  • By Eric_Froberg
  • joined 24 Jun'25 - 1 message
  • Washington, United States
I had one last month that would not drive if the tiller was turned to the right. I replaced the wiring harness to the handle and the the control pot, no luck. If the prox. sensor in the tiller arm is good then look at the harness leading to the drive motor, I've found a short in that which prevented travel.
  • Posted 26 Jun 2025 21:35
  • By Nick_Grubb
  • joined 18 Feb'25 - 17 messages
NG
Have you checked battery pack under a load ?
Put meter lead red (positive) into positive cable
Then put black lead (negative) into negative cable then try to move this will test battery pack under a load if it drops more than 2-3 bolts batteries are weak or bad
  • Posted 25 Jun 2025 22:40
  • By John_Bradley
  • joined 10 Aug'22 - 311 messages
Jb69
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
