Lift has Low speed But does not have High Speed.
As you are Moving Back and forth it starts getting sluggish. and then it will hesitate like it has no oil in it but the tank is full. it will lift and steer. and it has no High speed. any Ideas what it Could Be. Thanks
  • Posted 21 Mar 2023 08:29
  • By Rat1
  • joined 6 Apr'19 - 12 messages
i find it odd that both pothole switches were bad but if they were then that is one less component to deal with since you replaced them.
There is one other switch that affects the drive and that is the elevation switch at the base of the scissor arms. If that switch is bad and it thinks the scissor assy is elevated it will not drive fast.
Now depending on what type of control this unit has (bang bang or proportional) the pressure readings will differ. The service material gives you the factory pressure settings for main relief, steering, etc. You can get that off JLG's website if you haven't already.
  • Posted 9 Apr 2023 00:33
Ok Did some Checking and found Two of the pothole switches are Bad Changed them out and still have the same problem. also pulled a pressure Reading and found low Pressure around 12 to 1500 psi. Replaced the pump and still have the same issue. Batteries Check Good and The motor is Good. Thanks
  • Posted 7 Apr 2023 00:20
  • By Rat1
Ok Thanks I will check that out and let you know.
  • Posted 24 Mar 2023 00:29
  • By Rat1
generally when you loose highspeed it is associated with safety switches like the pothole protection circuit that is used when the platform is elevated. I would check those first. There are switch(s) located in the pothole arm linkage and also at the base of the scissor arms that trigger when the platform is elevated to slow the lift travel down. If those check out ok then you will have to resort to checking hydraulic pressures down on the hydraulic control valve, one of those valves may be sticking. There are a couple valves that deal with fwd/rev travel, a dump valve and some other valves like a flow control valve and a check valve.
You can go to JLG's website and get the service book and it will guide you step by step through the process in the troubleshooting section. They are serial number specific so pay attention to that when looking it up.
  • Posted 23 Mar 2023 23:40
edition #1299 - 17 September 2026
With the world changing, in seemingly too many ways to fully comprehend, businesses need to be agile enough to change with it... Continue reading
Taylor TXB180S
Unicarriers FD80-2
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
