LIFT GIVING ERROR CODE 60
My husband is working on a lift that keeps giving a error code 60. Can some one please explain how to clear code and repair the problem associated with it.
  • Posted 12 Jun 2007 23:48
  • By tim_g
  • joined 12 Jun'07 - 1 message
Thanks Swoop223, I will go through these proceedures this morning and advise.
  • Posted 17 Mar 2020 23:15
  • By All Lift Tech
  • joined 3 Oct'10 - 57 messages
this code deals with a communication problem between the display and the logics
-check your cable and connections
-check the display for damage
-check the logics for damage
check the following wires for continuity
P3-4 to P6-4 (wire #12)
P3-5 to P6-3 (wire #16)
P6-2 to key switch (wire #4)
P6-1 to battery negative (wire #1)
P3-18 to key switch (wire #4)
P3-20, P3-21, P1-21 to battery negative (wire #1)
If all above checks ok then:
check for short to battery negative (wire#1) in the following wires:
wire #12
wire #16
wire #4
if any check shorted repair or replace wiring
Now from here it says to connect a spare display and turn on the key, if it checks NOT ok then fix shorts, if it does display properly then replace the logics.
So if you have another unit there like that one, remove the display out of it and plug it into this truck and see if that fixes the display or not (after you do all the previous tests.
  • Posted 17 Mar 2020 14:46
Having this issue on three lifts...could anybody help with Code E60..alln functions work..reading " dead " on this play and E60, thanks.
  • Posted 17 Mar 2020 07:09
  • By All Lift Tech
Thanks edward _t yes it is a bit old, but there are some problems I started in 2007 that i have not solved yet.......but I agree and will close this thread
  • Posted 4 Mar 2009 21:32
  • By Admin
  • joined 18 May'04 - 266 messages
  • Queensland, Australia
since this was a 2007 post, I sure hope the original poster got it worked out by now
  • Posted 4 Mar 2009 21:24
this code seems to always end with the replacement of the logics. No mader how much i clean the pins and check the wiring to logics it always end with replacement
  • Posted 4 Mar 2009 12:24
  • By Jan_Haayer
  • joined 4 Mar'09 - 18 messages
  • Nova Scotia, Canada
Komatsu FD25T17
Toyota 3FD100
Komatsu FD25T17
Toyota 3FD100
Bolzoni SpA (Group HQ)
