LIFT FAULT
Hi
My Hyster reach truck is lifting very slowly but descends at normal speed. No error codes coming up.. Any ideas please?
  • Posted 28 Feb 2017 01:20
  • By darryl_m
  • joined 28 Feb'17 - 10 messages
  • Mid Glam, United Kingdom
D Moseley
Thanks for the reply Kevin, The full model is Hyster R1.6N, Serial No: C435T0185BZ
Regards,
  • Posted 28 Feb 2017 02:30
  • By darryl_m
D Moseley
Could be a number of things....is lift the only function that is slow?..Is it slow tilting and reaching....???? Could be low hydraulic fluid....Hyd filter needs replaced....low lift pressure getting to the lift cylinders.....mast binding up due to worn or damaged rollers...hyd pump worn or not putting out correct pressure....bypass line or valve stuck open partially...have a full model and serial number for the truck..????
  • Posted 28 Feb 2017 02:24
  • By kevin_t
Taylor TT300
Maxlion FD50T
Taylor TT300
Maxlion FD50T
