Lift Drifting
I have a raymond EASi Pacer docker truck that i cant seem to figure out why it wont stop lowering on its own. Ive checked and actuated both the prop and load hold solenoid valves, also checked my coils and wiring and everything is functioning correctly. The only other thing i havent checked is the check valve at the bottom of the cylinders. I had also checked handle for correct function through the maintenance mode analog and outputs section. Any help would be greatly appreciated.
Thank You
  • Posted 23 Jun 2016 23:31
  • By kyle_c
  • joined 23 Jun'16 - 2 messages
Reseal all of your lift cylinders
  • Posted 8 Jul 2020 06:41
  • By JerbinFett
  • joined 7 Jul'20 - 3 messages
  • Arizona, United States
If it stops drifting when the battery is unplugged, the problem is electrical in nature. If it continues with the battery unplugged the problem would be trash in or a faulty load holding valve or lift relief valve.
  • Posted 26 Jun 2016 00:05
  • By buddy_g
  • joined 15 Jun'16 - 6 messages
  • Louisiana, United States
SMV (Konecranes) 4632CC5
Nagano NUZ090D
Oxford Ct, United States
