lift cut out
Good morning, I've got a Yale NDR030EA swing reach with a lift cut out issue I'm trying to solve. The lift handle went out, I replaced it and got the unit up and running again but now when the carriage is raised above 3-4 feet the lift function slows. Travel is fine no effect to it but the raise and lower is slow until the carriage goes below 3-4 feet. I can lower it all the way down and everything resets too normal until the carriage is raised again then the cycle repeats. Does anyone know what causes this? could it be calibration of the height needs learning?
  • Posted 26 Feb 2025 22:57
  • By Nick_Grubb
  • joined 18 Feb'25 - 17 messages
NG
Thank you sir and I found the issue on the other unit. The steer encoder, and ring are missing. I found a junk unit that still has all the parts so I will start there. Again thank you for your time, just a few minutes has saved me much headache.
  • Posted 27 Feb 2025 00:13
  • By Nick_Grubb
NG
Nick,
Will need to complete the setup for the raise and lower of the mast. The encoder needs to see the mast completely raised then lowered through the dash display. Each function must be saved into the controller. The password for the display is all 5s. Go to calibration and mast. Good Luck.
  • Posted 26 Feb 2025 23:23
  • By Fishmech
  • Virginia, United States
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
Toyota 8FD30
Singapore
USD18,000
Aichi SR10C1SM
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
