Leaking Hydraulics
I have a unit that has about 3800 hrs on it. In the last 200 hours every single hyd. cylinder on the unit has started to leak. I would say I have above average working conditions. Any ideas or thoughts on why this is happening or is this just bad luck? Thanks.
  • Posted 25 Jan 2014 09:59
  • By ATK1
  • joined 27 Jan'12 - 75 messages
  • South Dakota, United States
allenk@ntlifts.com
Showing items 1 - 20 of 20 results.
If the temp is cold you need a lighter oil then 68, and if hyd oil has never been changed then oil could break down. to check pressure for lifting just hook a pressure gauge into a side shift hose
  • Posted 22 May 2015 11:37
  • By edward_m
  • joined 11 May'15 - 111 messages
Since I've had two leaks on this machine, cylinder seal, and O-ring on a connection under floor, noted earlier, its time to get the pressure checked. Thanks for all your suggestions.
  • Posted 28 Sep 2014 05:14
  • By stan_k
  • joined 23 Sep'14 - 8 messages
  • Wisconsin, United States
I agree that other leaks should appear but the Clark was an electric unit & the tilt, s/s & p/s were all powered by the main hyd pump on this unit yet none of the other systems leaked. My theory was the hoist was the only circuit that accumulated oil rather than just use the pressure.
I think I would err on the side of caution & drain the hyd tank & check for debris at a minimum along with checking the pressures. I would think that high pressures would also cause other cyl's to leak or have other symptoms.
Do Linde's have a high pressure filter after the hyd pump? Do they use the hyd pump to power the hydros or do the hydros have their own pumps? Not trying to break your b*lls- just don't know how they're set up.
  • Posted 28 Sep 2014 00:32
  • By bbforks
yeah bb that was one of my thoughts too but these linde's drive everything through the hydraulic system, drive, hydraulics, steering and in some cases even the cooling fan.
If contaminated fluid from a failing pump was the case he should be seeing fluid leaks from several sources, not just the one.
I'm thinking some sort of pressure issue.
He should have the pressures checked and make sure they are withing machine specs. If it's high this could cause this. That would be the first thing to check anyway on these machines.
  • Posted 28 Sep 2014 00:05
  • Modified 28 Sep 2014 00:06 by poster
I've had a faulty hydraulic pump throw sand like particles into the hyd system- learned this one the hard way- same cyl was repacked 4 times within a year (telescoping hoist cyl in a C500 clark)- after the 3rd time (hyd vendor would no longer warranty) apart we carefully inspected each seal, gland nut- etc & found metalic "sand"at each point- checked & found "sand" at bottom of hyd tank & covering filter media.
Truck had no hyd symptoms other than hoist cyl leak- removed hyd pump & found bearing surfaces rough (chrome was gone) & gears pitted. It's a long shot but worth a look if no other cause can be found.
  • Posted 27 Sep 2014 12:53
  • By bbforks
well i guess that rules that possibility out.
weather might play a part in it but generally it wouldn't show till it got cold. Seals harden up when cold and get soft when warm. When warm they seal better.
well i would of thought dirt around the ram seals but he did say a clean environment so maybe thats not it as i originally thought. edited
  • Posted 27 Sep 2014 11:48
  • Modified 28 Sep 2014 00:01 by poster
Warehouse is not refrigerated. However, it is not heated in the winter. We're located in the northern U.S. So, warehouse definitely gets down into the lower 40's F. Maybe into 30's during the dead of winter.
I have checked the rod for scoring. No scoring, pitting, or flaking on the cylinder.
  • Posted 27 Sep 2014 08:26
  • By stan_k
ok.... does it run into a refrigerated cooler at any time? or is this just a standard warehouse?
karait's suggestion has some merit...
look at the cylinder pistons real carefully and check them for any pitting or flaking. Extend them fully and check the whole piston and see if you find anything like this.
  • Posted 25 Sep 2014 20:12
  • Modified 25 Sep 2014 20:13 by poster
Using standard oil that came in truck when new.
  • Posted 25 Sep 2014 08:34
  • By stan_k
You mention the truck is being used in a food warehouse.
Is it running on standard hydraulic oil OR has the customer insisted it have food safe hydraulic oil put in the trucks hydraulic system instead?
  • Posted 25 Sep 2014 03:24
  • By Forkingabout
  • england, United Kingdom
excessive high temperature does all seals to leak som oil can better resist high temperature
  • Posted 25 Sep 2014 03:23
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Environment is as good as it gets. Its a food warehouse. Lift is used to load and unload trucks, and stack pallets. Operator is extremely conscientious. Have not lost enough fluid to top off fluid.
  • Posted 25 Sep 2014 01:50
  • By stan_k
Just make sure to inspect the old seals when the rebuild is done to confirm what the issue was- sometimes this is the most important part of the job to stop repetitive repairs
  • Posted 24 Sep 2014 23:25
  • By bbforks
Stan_k
In 2011-12 there was a series of 386 Linde trucks with some problems with the lift cylinder pistons. The surface of the piston went rough and it caused the defects on seals. Perhaps this is the case with your truck.
The replacement of the seal kit on lift cylinder is a standard, altough hard job, no special tools required. Takes about 3 hours for skilled technician.
  • Posted 24 Sep 2014 22:41
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
other then the previously mentioned incorrect hydraulic fluid
what type of environment does this truck run in?
what does it transport?
in alot of cases a dirty envrionment that allows production materials to get on the truck can cause something like this if those materials are caustic or gritty and can get into the cylinder packing seals.
just another out of the box thought :o)
  • Posted 24 Sep 2014 21:46
I have a Linde E-18 purchased new in 2012. At 1300 hours (hours are accurate) it blew out an O-Ring in the manifold under the floor board. Once the repair on this was complete, a lift cylinder seal failed as well. This machine is operated in a clean environment and is not overloaded, or pushed to the max lift capacity.
Anyone have ideas why this is happening?
Lift cylinder has not been repaired, yet. How difficult is it to remove and put new seal in?
This was still under warranty period. However, I discovered that there is no warranty on hydraulics, drive train only.
  • Posted 24 Sep 2014 03:01
  • By stan_k
For normal application, for this trucks, you should use ISO - L - HM 68 or HLP ISO VG 68.
I would suggest to care about the quality of the oil.
The hydrostatic transmission is very sensitive.
Anyway, it's rather strange for me thet the truck from 2003 (over 10 years old) has only 3800 hours. It means it worked
~ 350-400 hours a year.
I would check the real working hours (ask Linde service to check the value from the control module)
I would'n t be suprised, if the real working hours number was 4-5 times bigger.
Besides, check the pressure form the control valve section responsible for lifting/lowering.
The maximum pressure value from the tandem pump is ~ 230 bar. It's a reduced in the control valve to 170-180 bar (depending upon the mast type etc.) But anyway, even 230 bar shouldn't be so disastrous for the mast cylinders.
From the other hand, if we consider, that the real working hours can be much bigger, perhaps the seals just reached their lifetime.
  • Posted 28 Jan 2014 00:22
  • Modified 28 Jan 2014 01:13 by poster
  • By Karait
  • Poland
J.M.
That would be H2X392P. Thanks
  • Posted 27 Jan 2014 23:32
  • By ATK1
allenk@ntlifts.com
I've seen this happen before on a Cesab when a technician put the wrong spec hydraulic oil in.
What's the first few numbers on the data plate so I can id the family type?
H2X ???
Ill have a look in the manual & see what the hydraulic pressure relief valve should open at.
  • Posted 25 Jan 2014 21:06
  • By Forkingabout
A couple of thoughts... wrong type of hyd. oil, pressure regulator for hyd. circuit faulty over pressurizing hyd, circuit.
  • Posted 25 Jan 2014 10:16
  • By bbforks
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
UN Forklift FBR25NQC3
Unicarriers FD80-2
Bolzoni SpA (Group HQ)
Philadephia, PA, United States
Chandler, United States
