KOMATSU FD30T-10
Serial Number: 226879
anyone have a manual for this old diesel,need to know how to time the injector pump to the engine.....the Fuel filter isn't very old,the truck starts and runs but it drops down to and idle at times and has no throttle response,shop says its the injector pump......I don't work on a lot of diesels so am taking their word for it,getting a quote and see if the customer is going to have the pump changed out or not,just want to be prepared in case they do.
  • Posted 5 Nov 2013 05:45
  • By kevin_t
Always pressurize fuel tank and blow fuel away from the tank. Keeps you from reintroducing possible blockage back into the tank:).
  • Posted 9 Nov 2013 10:41
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Got it sorted out and running better yesterday,took the fuel lines off and blew them all out with air,removed the small shut off valve at the tank and blew that out,did find some crud and debris at that.....installed a new fuel filter even tho the one on it only had 30 hours on it.....ran good afterwards and haven't heard back from the customer....YET
  • Posted 7 Nov 2013 07:28
  • By kevin_t
Did that solve the problem.
Titus
  • Posted 7 Nov 2013 07:22
  • By Titus
  • joined 6 Jul'10 - 185 messages
Hello,
Remove the 2 banjo bolts on top of the fuel filter, in the one that comes from the fuel tank there's a very small filter screwed inside. Remove and clean the hose.
Kind regards
Marcb
  • Posted 7 Nov 2013 05:45
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
I am not familiar with this particular truck nor engine but i would check for a final chance filter located in the injector pump. It is usually found beneath the fuel inlet on the injector pump. Just a thought.
  • Posted 5 Nov 2013 09:38
  • By RCAV8TOR
  • Alabama, United States
THank You very much for the info....will check this
  • Posted 5 Nov 2013 06:23
  • By kevin_t
From what you have described I would check for a fuel blockage very often fuel starvation will cause the engine to drop to tick over revs and won't rev up, check stack tube from fuel tank for blockage,
Check any banjo bolt connections debri can collect at these points, if your truck has a hand primer pump situated over the fuel filter and the revs fall to tick over speed observe if the primer button has pull down this is a good sign of a blockage. I always think its worth checking for a blockage before moving onto the injector pump.
Regards Titus
  • Posted 5 Nov 2013 06:11
  • By Titus
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
UN Forklift FB25N1QZ1
Terberg YT223
RAEDER-VOGEL
Board member, UKMHA
