Komatsu Diagnostics
Wanted to buy, beg or steal. Diagnostics kit for USA spec engine management system fitted to Komatsu FG25 SHT Ser No 5904828.
Am told it is same as the Nissan system but not sure. Can anyone help.
  • Posted 2 Mar 2009 20:04
  • By veteran
  • joined 8 Jan'09 - 11 messages
  • Leicestershire, United Kingdom
Email me and I can email you the procedure to read the codes via the check engine lamp and what the codes mean.
Doc
  • Posted 11 Mar 2009 09:39
  • By Drlifttruck
  • joined 20 Nov'05 - 106 messages
Lift Trucks all the same, just painted different colors.
Doc
Email: kulsh@forkliftservice.net
Hi Dr. Model is FG25SHT Serial No 5904828
  • Posted 10 Mar 2009 20:45
  • By veteran
The Dr. may be able to help you here.
Please email the Doc the model and serial of your forklift.
The check engine lamp should be illuminated.
I can give you a procedure to access the the code via the check engine lamp, I am sure.
Regards,
Doc
  • Posted 7 Mar 2009 10:42
  • By Drlifttruck
Doc
The info on the valve cover is, Nissan K25L October 2005. The symptoms are that the engine will start first turn of the key, will tick over but will not rev up.
  • Posted 6 Mar 2009 19:56
  • By veteran
Tier 3 is what CARB?
No EPA Tier 3 yet.
That Happens in 2010
Educate yourself.
Doc
  • Posted 6 Mar 2009 13:00
  • By Drlifttruck
Doc
Is there a Data tag on the valve cover that gives year of production.
The injector problem was resolved back in like 2005 I am thinking?
Komatsu does not use the same enging config that Nissan, Cat or Mitsu uses.
It is more closley related to Tusk, AKA Kalmar, and TCM.
Let me know.
Regards,
Doc
  • Posted 6 Mar 2009 12:59
  • By Drlifttruck
Doc
Thanks howard, will give it a go.
  • Posted 4 Mar 2009 02:12
  • By veteran
as far as my guys in the shop can tell,if it is a tier 3 propane system they are the same.We have encountered a starting problem (intermittent) with this system and it has been a faulty LPG injector.The factory said to warm the injector up with a heat gun and it proved the bad injector.
  • Posted 3 Mar 2009 02:42
  • By howard_w
  • joined 28 Feb'09 - 7 messages
  • Colorado, United States
Hawker Powersource, Inc.
Briefs United States
