Jungheinrich reach drive fault
Junghienrich ETVA 12.5 G 115-650DZ
Ser 7.7516.01.01
Type 853-3000. Y.O.M 1988
Hi all,
I have a reach truck with no drive. if you press the accelerator pedal down fully after about 3 seconds the truck shoots forward at full power( I think the bypass contactor is coming in ) they is no pulse to the drive motor. Has anyone had this fault before, could it be the accelerator pedal if so how do i test it?
Pete
  • Posted 1 Nov 2011 04:46
  • By peter_d
  • joined 4 Jun'09 - 50 messages
  • manchester, United Kingdom
Hi mate
I think i have a paper copy at the workshop will check in the morn ing, however if anyone has the info available please contribute.
Regards
  • Posted 2 Nov 2011 06:28
  • By elektrodrive
enquiries@elektrodrive.co.uk
HI elektrodrive.
The error looks like a letter C, this is dsiplayed on tor of a silver card probably the logic card, I have no knowledge of this system whats so ever. If you could post the results of the error I would be must grateful.
Pete
  • Posted 2 Nov 2011 05:35
  • By peter_d
HI there
If this uses the old Mikropulse system, you can look at the drive controller and on the logic card LCD display segment there should be an indicator with an error.
  • Posted 2 Nov 2011 05:01
  • By elektrodrive
Hi , have you check you accelerator pedal? In this pedal there is a resistor , it is possible this give wrong ohm
  • Posted 2 Nov 2011 04:42
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Kai von Berg Kai von Berg
Linde Material Handling
