Jungheinrich ETV 214 Joystick no work
The joystick on an ETV 214 is not working. Has anyone had this problem? I can't figure out if the problem is with the joystick or if it's a software problem. Thankyou!!
Where can I find a schematic diagram?
  • Posted 23 Oct 2024 05:17
  • Modified 25 Oct 2024 03:15 by poster
  • By Marcelomac
  • joined 23 Oct'24 - 3 messages
  • Argentina
1. Check Connections: Inspect and reconnect the joystick wiring.
2. Test the Joystick: Swap with another machine if possible.
3. Software/Calibration Check: Look for errors, recalibrate, or reset.
4. Joystick Replacement: If faulty, consider replacing.
5. Find Schematic Diagram: Check the manual, manufacturer's website, contact support, or explore online forums.
Let me know if you need any further clarification!
  • Posted 28 Oct 2024 04:52
  • By Nick_Gold
  • joined 27 Oct'24 - 2 messages
  • Washington, United States
Joysticks can be calibrated, ask a locao Jungheinrich dealer to calibrate the joystick, setting correct 0 positions.
  • Posted 27 Oct 2024 18:56
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
There is no error code on the screen, so I assume it is a physical problem with the joystickt thn. Thankyou.
  • Posted 25 Oct 2024 01:15
  • By Marcelomac
  • Argentina
If any function of joystick is not working then the joystick is faulty. any error code in the display?
  • Posted 24 Oct 2024 19:12
  • By Syed
  • joined 14 May'15 - 197 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
The problem is that the stacker works but the control lever does not work. I hope you can help me with what the problem could be.
  • Posted 23 Oct 2024 23:05
  • By Marcelomac
  • Argentina
edition #1285 - 11 June 2026
