Jungheinrich ETV 214/16 mp1514 question
Hello dear colleagues,
i have a problem with battery measuring on the above mentioned forklift.
there are two mp1514 boards,one for drive,other for lifting.
So the problem is that LISA shows 0% battery,and inhibits lift.
As far as i know,the one in drive is the one that measures the battery,so i changed drive and lift positions ,and the battery gauge was showing 100% battery until i set the default parameters,and after reset,the battery is showing again 0% in the other mp 1514,and the interface 8 is showing red,not online...did anyone ever solved that problem?
we checked the installation/cables,pin by pin,everything checks out by schematic ,but the interface 8 is offline,interface 4 and 8 are on the same board,all the wires are ok but it doesn't go online,and battery measurement is 0%...
  • Posted 16 Aug 2019 07:25
  • Discussion started by HUZO
  • HR, Croatia
those who believe in telekinetics,raise my hand!
Did you create a back up before reseting the machine? If so just reload that back in to it.
  • Posted 20 Aug 2019 12:31
  • Reply by Service_T
  • Kansas, United States
ServiceT
Write it like this
HUZO1983 at GMAIL dot COM
Cheers from Admin
  • Admin
  • Posted 18 Aug 2019 05:41
  • Reply by Admin
  • Queensland, Australia
again...url removed....
  • Posted 18 Aug 2019 05:15
  • Reply by HUZO
  • HR, Croatia
Send message in "signature"
  • Posted 18 Aug 2019 05:13
  • Modified 18 Aug 2019 05:15 by poster
  • Reply by ilinca_v
  • Prahova, Romania
Best Regards,
cristivirgil@yahoo.com
part of the message was deleted,send you what?
  • Posted 18 Aug 2019 04:59
  • Reply by HUZO
  • HR, Croatia
Send me a mail.I will help you !
  • Posted 18 Aug 2019 04:58
  • Reply by ilinca_v
  • Prahova, Romania
Best Regards,
no errors,no codes...i am forklift service techinican ,not a novice in the field...just to get that straight.We have tried everything...and i got to a conclusion that the "drive" mp1514 measures the battery ,probably the processor has a problem,so i'm asking if someone solved it...
  • Posted 17 Aug 2019 21:47
  • Reply by HUZO
  • HR, Croatia
Is there a code number on display? check on controller number of flashes, send images to my email
  • Posted 17 Aug 2019 21:21
  • Reply by prepaito_d
  • iztapalapa, Mexico
Whatsapp +525513637801
no,the fuses are all ok,there is voltage on all wires,connections etc...the truck works,drives,but lift doesn't work because the battery shows 0%
  • Posted 17 Aug 2019 16:14
  • Reply by HUZO
  • HR, Croatia
Did you check fuses? I had same problem on a Efg, it was a fuse below battery conector, send dash image to my email to help you
  • Posted 16 Aug 2019 07:55
SMV (Konecranes) 4531CC5
UN Forklift FGL18T
Ottumwa, IA, United States
Harrisburg, SD, United States
Wentzville, MO, United States
