Hello
Did you reset the truck totally?
205 means - no multipilot.
To reset the truck, you should unplug the multipilot, switch off the truck, switch off the emergency switch, unplug the battery. Wait one minute, in the meanwhile plug the multipilot, than plug the battery, switch on the emergency switch etc.
If it doesn't help, you probably may have the problem with the cables.
