My jungheinrich reach truck etv 116 show info 26 and temperature sing with low lift please gude me
Thanks
I will check motor 1st
Check motor cables, motor or repair/replace controller
Regards
Hello All
I have a problem like C016 and E011.
The truck can't do anything.
Any suggest to fix the problem ?
thank you
thanks for the help, we found a broken connection behind the line contactor. all is now well.
Dado
Power release low voltage, Travel/Steer:Capacitor voltage drops
to 30V (48V) for 0.5seconds.
Cause: Switch truck on and off; check battery; check battery cable connections; check fuse; Check power connections; replace
component.
Check line contactor, and look for voltage drop.
Regards
