Jungheinrich EFG320 - Electric forklift - Error code 019
Dear all,
Our Jungheinrich EFG320 forklift error code 019 is displaying, Can you please suggest to check the possible cause to rectify the problem.
please help me to sort our the problem
  • Posted 10 Jun 2016 20:33
  • Modified 13 Jun 2016 19:13 by poster
  • Discussion started by ponnu
  • Muscut, Oman
Check the black and white wire pins with multi meter on diode mode, it will show approx 0.53 in one direction, the other direction nothing, red and blue pin also nothing in both directions.
otherwise you need to change with new sensor bearing and observe the condition.
  • Posted 23 May 2020 17:48
  • Reply by ponnu
  • Muscut, Oman
Hello I have the same problems motor and controller are not grounded.. how can you test those bearing encoder ? EFG320
Thanks
Also say inf:08
  • Posted 22 May 2020 23:47
  • Modified 23 May 2020 00:13 by poster
  • Reply by vincent_l
  • Quebec, Canada
The only thing to rectify this is to replaced the shorted controllers, or maybe there's a shorted line contacts to the chassy having an open wire.
  • Posted 20 Sep 2016 17:24
  • Reply by scooby
  • south cotabato, Philippines
Error 019 is a power/voltage failure.
Like Monty/Elektrodrive says, check your earth cables.
Are you getting a code that starts with C displayed too? This may help by narrowing it down to which controller has detected the voltage drop
  • Posted 12 Jul 2016 06:22
  • Reply by little_forker
I know it's a long shot and may not be related but always worth a check.
I had this error twice on the same truck and I found earth leakage to lift motor. Cleared the earth and truck worked a treat. A few months later same problem and the controller itself had failed.
  • Posted 8 Jul 2016 01:30
  • Reply by elektrodrive
enquiries@elektrodrive.co.uk
Open controllers and check for loose connections.
Make sure all power connections from controllers to motors are secure.
It is possible that the replacement encoder has failed, it is easy enough to damage them when fitting. They should always be pressed on and not tapped with a hammer or other heavy object.
  • Posted 5 Jul 2016 00:05
  • Reply by Roibeard
  • Dublin, Ireland
Forklift was running for a week time. again the same error code 019 is showing. Forklift not moving and pump also not working. Checked all the three motors sensor bearings all are ok.
Please anybody can give further clue to sort out the problem.
  • Posted 4 Jul 2016 18:00
  • Reply by ponnu
  • Muscut, Oman
Thank you verymuch for your clue. One of the sensor bearing is the problem. we have rectified. Once again thanks
  • Posted 16 Jun 2016 17:05
  • Reply by ponnu
  • Muscut, Oman
Looks like it could be speed sensor bearing in one of the motors.
  • Posted 13 Jun 2016 23:13
  • Reply by heightlift
  • North, United Kingdom
Thanks for your reply. Please find the detail
Sr.nr. FN324896
Year of manufacturing 2005
  • Posted 13 Jun 2016 22:16
  • Reply by ponnu
  • Muscut, Oman
If you include serial number and age it might be easier to check.
  • Posted 13 Jun 2016 20:55
Hello Guys anybody can explain the problem related to the error 019 in the Jungheinrich EFG320 forklift
  • Posted 13 Jun 2016 19:16
  • Reply by ponnu
  • Muscut, Oman
edition #1235 - 19 June 2025
JLG 1932R
JLG 1932R 2017
Flesherton, Ontario, Canada
Hangcha CBD15
China
USD1,600
Ncn 85TH
Ncn 85TH 2017
Hangcha CBD15
China
USD1,600
VETTER Industrie GmbH
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
