Joystick problems
Joystick quit working for forward and reverse yet all the buttons on the stick still function as they should. Had a couple of different repair companies out to try and fix it, one spent several hours trying to trace the problem with no success, the other said the joystick is shot and the parts not available - recommends we just buy a new machine!
Any ideas as to the possible problem?
  • Posted 29 Nov 2014 09:34
  • By Snakebyte
  • joined 29 Nov'14 - 2 messages
  • Alberta, Canada
after doing a little checking i found a service gram from hyster about these handles, the service gram mainly dealt with repairing/retrofitting the upper part of the handle to make it servicable, the old style handles were not.
But there is a note in this bulletin that plainly states:
The lower control mechanism is non-repairable and the entire control handle must be replaced if it is defective.
As far as these tech's that came out and looked at it were they hyster techs? or Independent Techs? In either case they were wrong.. you can get a handle for this truck New or Reman
the New part number is 1554722 and the Reman part numbers are 4001993 and R4001993.
Sounds like these guys didn't know what they were doing and besides it is a heck of alot less expensive to replace the handle assy than replacing a $45k lifttruck just because of something like this ;o)
  • Posted 29 Nov 2014 13:33
Did they check the potentiometer....would of been my first check/diagnosis???? What all did they do/check????? What kind of repqir companies looked at it.....forklift repair companies.......Forklift dealers????
  • Posted 29 Nov 2014 12:10
  • Modified 29 Nov 2014 12:12 by poster
  • By kevin_t
Sorry - C470N03043C
  • Posted 29 Nov 2014 10:33
  • By Snakebyte
  • Alberta, Canada
Serial number of truck????
  • Posted 29 Nov 2014 10:17
  • By kevin_t
Sue Tomic Sue Tomic
Linde Material Handling
Terberg YT223
Ice 24INCH-AUTO-SCRUBBER
USD6,396
Sue Tomic Sue Tomic
