Iso: Injection pump Zexel 104640-0643
Hello,
I run into a big problem. After I left my forklift outside for the last month without using it now it won't start.
I got a diesel mechanic to take a look at it and he concluded i have a bad injection pump.
It looks like the pump is discontinued from the manufacturer.
That's why I am posting here.
Does anyone has a used and working injection pump for a Yale diesel forklift?
Installed is a Zexel 104640-0643.
The only other option I would have is to take out the injection pump and let it repair.
Is there another option?
Thanks for any help or lead you might have.
  • Posted 18 Feb 2025 13:40
  • By Mathias_F
  • joined 22 Feb'23 - 3 messages
Mathias
Mathias,
First, since this lift has been sitting outside, pump some fuel inside a glass container and let it sit for 4 hours. If you have water in the fuel, you will see a distinct line where the fuel and water have separated. If so, drain the tank and all fuel lines. Replace fuel filters and fill tank with fresh fuel. Bleed the system and try to start. Since parts have become so expensive, I would take the pump off and take to a diesel shop. Good Luck.
  • Posted 24 Feb 2025 23:57
  • By Fishmech
  • Virginia, United States
SMV (Konecranes) 4545CCX5
Unicarriers FHGE35T5S
