Intermittently won't tilt back
Unit does not want to tilt back forward tilt is fine. Sounds like the engine will load up but it will not tilt already tried to change and calibrate the tilt censor with no success any help would be appreciated
  • Posted 5 Jan 2023 04:11
  • By shelbs
  • joined 4 Dec'22 - 3 messages
  • Michigan, United States
Bottom switch had a wire braking at the switch. It worked fine every time I had the switch off of the valve and was testing it with the display. But not when it was attached I appreciate the response though
  • Posted 6 Jan 2023 07:08
  • By shelbs
Look into the tilt switches on the control valve. There are 2.
  • Posted 6 Jan 2023 01:00
  • By ErichO
  • joined 26 Oct'21 - 83 messages
  • Washington, United States
SMV (Konecranes) 4531CC5
JCB 533-105
