Intermittent traction loss both directions
Hopefuly someone can help me, I have a PE-4500 AC with an intermittent problem. When traveling in either direction in high speed traction cuts out and message on the display reads return to neutral,Ive replaced pot and f/r switches and still the same,what i noticed though is when powering the machine on and going therough self test the line driver contactor doesnt pull in. But will pull in when requesting lift or traction but like I said start driving hit the high speed switch it gets to a certain speed and displays that msg.
  • Posted 7 Aug 2014 02:12
  • By stucktruck
  • joined 27 Nov'11 - 17 messages
  • New Jersey, United States
Check for a loose brake cam roller. It has just enough play to close the brake switch but as the lift bounces around the switch opens up.
  • Posted 1 Aug 2016 07:32
  • By jeffrey_r
  • joined 23 Jul'11 - 10 messages
check the mechanical condition of the handle at the pivoting points ,sometimes parts get worn out like the cam and bearing wich actuates brake switch causing all sorts of trouble... the axle and bushings where the springs are also worns out quickly.
just out the top of my head, could be other things tought
  • Posted 11 Aug 2014 13:30
  • By cubapnea
  • joined 3 Apr'13 - 24 messages
check for an intermittent connection in the handle arm cable.
  • Posted 7 Aug 2014 21:51
  • By ctech
  • joined 29 Nov'12 - 11 messages
  • United States
Hangcha FLDCXT160
Nagano NUL120-6
Michel Denis Michel Denis
Hangcha FLDCXT160
Nagano NUL120-6
