intermittent code 228
s/n H160N02399Y Customer called me and stated intermittent fault 228. Lack of power. I checked for any loose connections, worn motor brushes, worn steer linkage. Drive test did not bring back fault. Any suggestions? Thanks.
  • Posted 9 Mar 2016 02:08
  • By roadtek
  • joined 4 Dec'07 - 123 messages
Show 228 01 and 228 33
  • Posted 9 Jul 2022 00:08
  • By Cleiton
  • joined 8 Jul'22 - 2 messages
  • Brazil
Cleiton nova
Code does not state if traction is reduced. My guess is it probably does.
  • Posted 21 Apr 2016 01:11
  • By BREWSKI
thanks. Will that cause traction speed reduction when the fault is live? He was stating truck travels slow, but I remember his stating there was no raise so you're probably on the mark.
  • Posted 21 Apr 2016 00:57
  • By roadtek
Code 228 is open pump contact coil. Check wiring to coil and check coil resistance. I think it should be about 15 Ohms.
  • Posted 21 Apr 2016 00:53
  • By BREWSKI
Spoke to customer and he swore display showed 228. ???
  • Posted 21 Apr 2016 00:34
  • By roadtek
Not at all. Customer is stating he see's 228 as a fault. Should there be 3 or 4 digits for a code?
  • Posted 17 Mar 2016 21:58
  • By roadtek
Are you sure it is code 228?
  • Posted 15 Mar 2016 01:13
  • By BREWSKI
TCM FHD105Z
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
REPOWERTEK Inc
Sue Tomic Sue Tomic
TCM FHD105Z
USD1
Sue Tomic Sue Tomic
