intermittant no start,turnes over,no spark,let sit then start.
we have replaced distributor,coil,spark plugs and revolution box. this unit has chevy engine. whats left other than wiring to cause this issue.
  • Posted 24 Nov 2010 03:04
  • By jerry_c
  • joined 5 Oct'10 - 26 messages
I know it's a late reply to your question, but I recently encountered the same problem with a clients S55XM Hyster with a GM 3.0L lpg engine.
Turns out the engines had a problem with braking the starter pinion or even the nose cone of the starter when the engine fired immediately when the operator began cranking over the engine, so they incorporated a start delay electronic module just to the left of the battery, it would randomly fail and then start working again,, we removed it and installed a 12 volt DC delay timer we purchased for around $25 bucks from Fact#rymation, set it for about a 3 to 5 second delay & have hade no problems since... Much cheaper than the $1000.00 OEM
Hope this helps someone somewhere....
  • Posted 10 Mar 2023 01:40
  • By vibeguy
  • joined 25 Oct'17 - 4 messages
  • Tennessee, United States
Do it right the 1st time, and ya don't have a do over.
thank you for responding. we have checked wiring previously
  • Posted 25 Nov 2010 07:39
  • By jerry_c
Keyswitch and supply fuse, check input voltage to primary side of coil. if voltage is low trace it back to the poor connection. I had this happen wehere someone had replaced the fusible link on a truck with a 30A fuse and cheap holder, and corrosion on the output blade melted the fuse and holder so it only fed the coil intermittently.
Wiring is where I would have started, not ended... a distributor could have bought and paid for a nice FLUKE meter...
  • Posted 24 Nov 2010 14:41
  • Modified 24 Nov 2010 14:42 by poster
  • By steponmebbbboom
new lpg carb was installed also.
  • Posted 24 Nov 2010 06:25
  • By jerry_c
fuel supply is good. unit may run for 8 hrs. or 1.5 hrs. then quit
  • Posted 24 Nov 2010 03:25
  • By jerry_c
Check your fuel supply to carb
  • Posted 24 Nov 2010 03:08
  • By Prentice
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
East Syracuse, United States
Columbia, SC, United States
Saratoga, United States
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
Taylor XC300M
New - Sale & Hire
UN Forklift FD25T-C2JM1
