Intercambio de controladores de tracción.
Hello everyone. I have a STILL RX20-16 (6211 series) forklift. I have an error code D2503 which apparently indicates a defect in the right traction controller. I want to swap both traction controllers with each other, since they are identical, to check if the fault code changes. My question is whether, once the change is made, some type of calibration should be carried out through the display. (I do not have the STEDS program.) Thanks in advance.
  • Posted 10 Oct 2023 19:16
  • By Sondaestelar
  • joined 25 Aug'23 - 6 messages
  • Spain
Everything we call real is made of things that cannot be considered real.
VETTER Forks, Inc.
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
VETTER Forks, Inc.
