installed Q1 transistor, now code F5. What ya think EasiTek?
I had a hard code 23 with no traction. Replaced Q1 along with recs. I now have traction, but only drive for less than a minute when traction is losses and F5 appears. Any ideas
  • Posted 23 Sep 2017 03:29
  • By jonniClamCakes
  • joined 12 Nov'16 - 7 messages
Did you sort this out? An old Easi can run you in the poorhouse.
You can put multiple Q1s and rec ones, system cards, power cards. Very poor system. Before changing any parts on a RayRay, you must check for shorts to frame, battery shorts and proper static strap. Remove crappy insulators from heat sink and replace they burn holes and shirt under load. Anything less than 10 thousand ohms will shirt out Q1. Test each motor
Loose power cards, CD8 cards, Transistor modules plugs loose, best to have truck jacked up, driving wheel spinning and throttle engaged. Wiggle gently on all connections..you may locate bad connections
  • Posted 11 Oct 2017 12:02
  • By EasiTek
Ok- replaced VFM with known good. I travel for a bit, and now CODE 41. I don't have this code in my book, but must do with travel course it cuts in slow mode
  • Posted 23 Sep 2017 05:06
  • By jonniClamCakes
Combilift Ltd
Stu Jacover Stu Jacover
Chief executive officer, TVH
Combilift Ltd
