Hyster W40Z - Error Code AL 14
Randomly, the machine makes sudden stop with error code "AL 14". Does anybody know what AL 14 is? Thanks for your help.
  • Posted 12 Oct 2013 02:43
  • By KenLau
  • joined 12 Oct'13 - 1 message
Hello,
Make sure your batteries are fully charged and have good specific gravity.
Most of the problems I have had with these units is the Tiller head. Also bad wiring to the electric brake on drive motor
  • Posted 16 Oct 2013 03:16
  • By Prentice
Hi
ZAPI Controllers
W40Z [B218]
Dash Display
Version 1.08 = AL14
Earlier SW Versions = AL10
CONDITION
Voltage measured at field connections is not correct.
LOGIC
This fault occurs when the voltage measured at the field connections is not the expected value.
Cable connection to motor field is loose or damaged.
Verify connection of field wires to motor and controller.
Motor field winding is shorted to chassis.
Check motor field for shorts to chassis.
Main contactor coil shorted/open.
Check contactor coil for correct resistance of 45 to 55 ohms.
  • Posted 13 Oct 2013 06:57
  • Modified 13 Oct 2013 06:59 by poster
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Clark names Hawaiian dealer Dallax, TX, United States
Ottumwa, IA, United States
St. Louis, MO, United States
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
Manitou M50-4
Taylor TX175
New - Sale & Hire
Noblelift
Dwight Klappich Dwight Klappich
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Executive director, NT WorkSafe
Chief executive, Logistics UK
