Hyster H60FT Weak Brake Operation
Working on a Hyster H60FT, serial P177V13403T, customer concern was unit wasn't wanting to stop when stepping on brake/inching pedal. Tested unit and found that right side was only side locking up. Tried adjusting shoes with no change. Pulled left side apart and found the wheel cylinder was blown. Installed new wheel cylinders, brake shoes, and hub seals. Bled the brakes and unit still has a weak pedal like there is air in the system. When I bled the brakes I had a good solid stream of fluid coming out of the bleeders. Is it possible there is some sort of valve holding air for the auto brake (unit comes to stop by itself if throttle is not touched while in gear) setup on this unit? Or do I just need to keep bleeding this thing the old fashioned way?
  • Posted 3 Dec 2025 08:58
  • By Redheadleadsled
  • joined 3 Dec'25 - 1 message
  • Illinois, United States
Redhead,
Since wheel cylinder is leaking I would suspect master cylinder. Make sure all adjustment are correct first for brake pedal. With all adjustments correct and still sluggish brakes, replace the master cylinder. Good Luck
  • Posted 4 Dec 2025 04:20
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
Maxlion FDR50
Maxlion FG25
Lift Tek Elecar
Lift Tek Elecar
