Hyster H50H
Is there anyone out there familiar with this older lift. Serial # is D3D8910. This is a new account for me & I'm unfamiliar with how the hydraulics are set up. It has a manual trans with P/S. I believe it has a wet bell housing also.
Situation is that all hydraulic functions stopped working all of a sudden & the hydraulic tank overfilled. P/S doesn't work at all, hoist & tilt will operate very slowly ( & act like there's air in the system) at full governed RPM.
Any input or a hydraulic schematic would be greatly appreciated. Thanks
  • Posted 11 Jul 2017 03:50
  • By bbforks
I'll check on the pump. I have taken the filter housing off and re sealed with rtv several times but will check again. Its hard to find information on it because it seems like manuals are non existent. I'm hoping this problem also solves the lack of power in the monotrol system because even the smallest hill will stop it.
  • Posted 8 May 2019 15:39
  • By Spongebob
  • joined 29 Nov'18 - 11 messages
  • Washington, United States
Does the hydraulic pump have a large 3/4" whitworth (now I'm showing my age!) what looks like a blank plug looking from beneath, if it has, remove and the flow divider/priority valve is there over the years experience all it will need a check of the o rings and a clean up put everything back as you found it, number of turns on the threads etc, reassemble and test.
With oil overflowing check the scoop mounted on top of the bell housing above the torque converter loosen the two bolts beneath the cover plate push across till it stops then back a touch, I have had a few of these pick up scoops break off but invariably transmission oil is every where. Hope this helps good luck
  • Posted 5 May 2019 08:46
  • By algernon
  • joined 4 Nov'11 - 15 messages
  • Somerset, United Kingdom
the hyd filter set-up is critical on these old girls the filter can draw air internally.strip out the filter and check the tin part is sealed to the top plate of the filter housing
  • Posted 4 May 2019 06:49
  • By stackerhacker
  • joined 2 Mar'18 - 87 messages
  • glasgow, United Kingdom
I know it has been years since the last reply, but I am having the same problem with the same forklift. It has no power in drive or reverse, monotrol setup, and if it is revved at all during the first ten minutes of warm up the hydraulic pump losses prime. Will be replaceing suction hose soon, looked at hydraulic filter and it certanly easnt covered with gunk. Not sure where to head from here, I dont have a manual yet. Other than not having any power, once limped to full operating tempersture the hydraulics work great. Thanks.
  • Posted 2 May 2019 14:00
  • By Spongebob
Nope ,sound like a problem with the pump, is has a priority valve in it.steering gets the oil first no hydraulicsi would say pump.
  • Posted 18 Jul 2017 21:16
  • By towmotor
  • joined 19 Feb'07 - 360 messages
Would the wet bellhousing scavenging system cause a loss of hydraulics in both the hoist/tilt & P/S systems?
  • Posted 18 Jul 2017 09:52
  • By bbforks
you can get at the scavange tube from under the plate on top of the bellhousing ,you can adjust it by moving it side to side.
  • Posted 16 Jul 2017 03:17
  • By towmotor
Digging into memory.............Bellhousing is wet but there is a scavenge system. Check the oil scavenging in the bell housing.
There is a cast aluminium scavenge scoop in the bell housing. If it has become loose, broken or worn away by the scavenge ring (like a round cake tin) after it came loose, the bell housing will fill up.
Tim B
Hampshire , England.
PS if you ever need to separate the engine from the transmission you will need to loosen the scoop fastening capscrews so that it can be "extracted" from the scavenge ring.
  • Posted 13 Jul 2017 02:32
  • Modified 13 Jul 2017 02:35 by poster
  • By timothy_b
  • joined 21 Oct'15 - 39 messages
  • Hampshire, United Kingdom
unofficial info. man !
Tx for the input- I did think of that but the oil is not foamy & I had it running for about 1/2 hour & it never overflowed for me.
I'm thinking that either the flow divider or the pressure regulator to the P/S & trans circuit failed, I just don't have a parts or service manual to confirm what I find if I disassemble those 2 units.
  • Posted 13 Jul 2017 01:44
  • Modified 13 Jul 2017 01:45 by poster
  • By bbforks
Sounds like it is *** air. Is the hydraulic oil foamy?
The first and cheapest thing to try is replacing the suction house. I've seen where they get porous enough to *** in air but not enough to leak.
  • Posted 12 Jul 2017 20:59
  • By duodeluxe
  • United States
duodeluxe
edition #1235 - 19 June 2025
