Hyster H 4.0 FT cranking but not starting
We are using Hyster H4.0FT Seried N005B. The forklift is not starting. It is cranking. I have replaced the gas Filter, Spark Plugs and spark plug cables. When we try to start it explode also. It is not showing any fault. Can some one help me solve the problem.
  • Posted 26 Aug 2009 22:09
  • By navneet_d
  • joined 26 Aug'09 - 1 message
  • Abidjan, Cote D'ivoire
You may have a bad ignition module in the distributor, you don't say if or how the truck was running before you started throwing parts at it. Hysters & Yales are famous for this problem. Replace or clean the plugs when you change the module because you've been dumping a lot of fuel at them and they'll be soaked by now.
  • Posted 30 Aug 2009 04:25
  • By roadtech
Check your firing order. Could have gotten mixed up when they were replaced.
  • Posted 30 Aug 2009 01:33
  • By Forkliftt
  • Louisiana, United States
are you getting fuel to the carb
  • Posted 29 Aug 2009 23:27
  • By kevin_k
Is it getting fire to plug?Have you tried starting fluid at intake?More info would help
  • Posted 28 Aug 2009 22:22
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
