HYSTER E2.00XMS Error code - 16
model E2.00XMS , 1999 year, 48v.SERIAL No D114A02726W
Error code - 16, there is no movement
need a manual, any help
  • Posted 10 Oct 2013 06:46
  • By alexandr_k
  • joined 6 Dec'11 - 197 messages
  • Ukraine, Ukraine
code 41 is internal temp exceeded in controller.allow to cool it should be ok.check for causes of overloading or the internal temp sensor has failed
  • Posted 17 Nov 2019 03:39
  • By stackerhacker
  • joined 2 Mar'18 - 87 messages
  • glasgow, United Kingdom
Hi,I have problem with the same machine. Error code 41. Help me!
  • Posted 16 Nov 2019 16:46
  • By Andrey_Mihaylov
  • joined 16 Nov'19 - 4 messages
  • Bulgaria
Alexandr, check mail box
Regards
  • Posted 11 Oct 2013 05:59
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
nacsand at hotmail dot com
code 16 is usually battery over voltage. have you used a handset to set the voltage of the controllers to the actual battery voltage rather than a default setting for 36&48 volts? what happens in a dead battery 48 volt truck if the setting is the default, the controller may think it is a too hot 36 volt battery rather than a too dead 48 volt battery. that would be my assumption. setting it to the actual battery/truck voltage (function 17 I think, off the top of my head) should fix part of the problem and the other part will be fixed when the battery is good.
  • Posted 10 Oct 2013 20:02
UN Forklift FBR25NQC3
Taylor TT300
USD98,500
Noblelift
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
Yale Lift Truck Technologies
