Hydraulic pump
I have just changed the hydraulic pump that goes into the transmission under the left side foot well. All functions are very slow until you give it gas. Also screeching noise coming from transmission when tilt and sideshift are operated. Any ideas?
Thanks
  • Posted 21 Apr 2016 01:47
  • By dan_r
  • joined 21 Apr'16 - 32 messages
  • West yorkshire, United Kingdom
DMR
It sounds like there is a problem internal to the transmission. A gear pump has fixed displacement, so each revolution displaces the same volume of oil. If the displacement is low there must be something slipping in the pump drive.
  • Posted 21 Apr 2016 06:13
  • By BREWSKI
No power steering or hydraulics. Damage to drives in pump when i took the pump apart
  • Posted 21 Apr 2016 05:03
  • By dan_r
What was the problem with the original pump?
  • Posted 21 Apr 2016 04:38
  • By BREWSKI
Crown WP302020
Komatsu FD25T17
Libiao Robotics
